A trip over to RMK’s place a couple days ago got the wheels turning. Long story short, two JTR Orbit Shifters, which combined is two 18” drivers and 8kw of power, gave my quad 18’s and 16kw of power a run for their money! To be more specific, I feel his setup had greater output above 30hz, and mine had greater output from the mid 20’s on down.
The efficiency of the horn design definitely impressed me, so I started to look around. It didn’t take me long to find the GJALLARGORN on Ricci’s data-bass.com. From his measurements, just one gjallarhorn will outperform all four of my sealed 5400s from 16-40hz-ish, and obviously with far less power.
The plan is two build two of these, and re-use two of the 5400s from one of my sealed cabinets. That means I’ll still have two other sealed 5400s powered by a LG clone, which can help cover the top 60-80hz portion where the gjallarhorn may need some help. The only investment for me is the cost of the wood.
Ricci already emailed me the detailed plans, so all I have to do is find 4x8 sheets of quality Baltic birch and I’ll get started:)
UPDATE:
Edited by lukeamdman - Yesterday at 9:54 am
UPDATE:
He may need to update his homeowners insurance either way
