Originally Posted by
jpmst3
I am jealous!
Is that 5 sheets of 5x5 per cab?
These 5 sheets are enough to get me started on both. I hadn't bought BB from this supplier before, so I didn't want to order all the sheets at once in case the quality wasn't on par. This plywood seems to be pretty good. It's not as high quality as the stuff from Rockler, but Rockler doesn't have sheets large enough, and it's way more expensive.
Ricci
Wow...That is only 2500 cubes.
Yeah, the room is pretty small.
chrapladm
Luke are you going to CNC this subwoofer or build yourself?
I am not familiar on how to do the exterior panel cuts. They all match up great but my wood working skills are not that good. SO I wondered how you were going to attempt this. And maybe you will have lots of pictures if you do. I may just end up doing normal but joints myself with pocket screws for all panels.
5 sheets of 5x5 18mm and 2 sheets of 12mm. for one complete Ghorn. I will be using 8x4 sheets so four for me.
No CNC machine for me. Even if I had access to one I wouldn't use it. I've learned a lot the last couple years building speaker cabinets, and doing all the work yourself forces you to get creative sometimes.
I'll definitely take a lot of pictures, and tomorrow I'm picking up a table saw!
