Originally Posted by lukeamdman
I put glue down first on every joint before putting screws in.
That's definitely ideal, but one of the downsides of combining a Kreg screw to a joint that has thick glue on it is that as you tighten the screw the joint will "walk" slightly towards the direction the screw is going. Because of that slight movement on just about every joint, pretty much every piece of cross-bracing will have very slight dimension changes to make sure it's a snug fit.
Perhaps a way to avoid the "walking" would be to use a biscuit joiner. The biscuits would establish the location of the joint and then you would use pocket screws to hold it in place while the glue is drying.
