AVS › AVS Forum › Audio › DIY Speakers and Subs › Dual GJALLARHORNs!
Dual GJALLARHORNs! - Page 14
post #391 of 758
Originally Posted by dsl1 View Post
Starting today:
Gjallarhorn x 3
Ohorn x 1
Probably will take two weeks just to cut everything....
post #392 of 758
Starting today:
Gjallarhorn x 3
Ohorn x 1
Can barely imagine it, awesome!
post #393 of 758
I'd be lying if I said I hadn't already requested and received the Othorn plans from Ricci...
Depending on how I like the GH, I may sell two 5400's to fund a couple Othorn builds with the B&C 21" driver...
post #394 of 758
You let me know if you plan to do that. I might be interested in them LMS-U's of yours. biggrin.gif
post #395 of 758
Originally Posted by Ricci View Post
Tell me about it! I have been getting a LOT of requests for the plans since you started this thread not to mention all of the usual questions about construction and whether a cheap car woofer can be used! Jerk...biggrin.gif
How close are you anyway? Another week or two? I'm looking forward to hearing what you think.
Also if you get a chance post up those response flattening Gjallarhorn EQ settings for the minidsp and the DCX that I sent you. Since it seems like some others are building these it might be worthwhile to get that info out there more.
I'm getting really close. The Duratex is being delivered tomorrow, and I'll be finished with all the cross-bracing in a few days. The only pieces of cross-bracing I probably won't implement are those two 3/4" pieces that go from the back corner all the way up to the driver baffle.
The bottom plate and hatch won't take long at all, and thanks to all these pocket screws being inside the cabinet I won't have much sanding to do at all.
post #396 of 758
I would at least throw a simple triangle wedge or two in that back corner. The bottom is the least well braced panel in the whole cab. If you will be sitting the cabs on that panel it wont matter.
post #397 of 758
Sweet!
I may do the dual 15 build over the summer. The cool factor is just way too high!cool.gif
post #398 of 758
Oh of course! I'll be putting two 3/4" thick wedges there evenly spaced for sure.
post #399 of 758
Here's where I'm at with bracing. Should be done soon.
post #400 of 758
Wow. Nice work.
I really want to try a build like this, but I'll have to convince one of my concrete bunker home owning friends that we need to build one or two of these for their HT. Id be paying out structural damage claims for 20 years if I did this in my apartment.
post #401 of 758
Did you use a small screw driver to get in those small spaces?
post #402 of 758
No way! locals already have dibs!
post #403 of 758
That piece of pure awesomeness can fit in 2" spaces and it works great!
post #404 of 758
Just ordered one!
post #405 of 758
Also, because of the angle of the kreg screws, the 90 degree turn on the Milwaukee is too sharp. I use this in combination and it works perfectly:
post #406 of 758
Ah thats makes more sense now.
post #407 of 758
What exactly is that tool called?
post #408 of 758
This one looks just like the kit I have, only mine was made by Stanley:
http://www.amazon.com/TEKTON-2837-Ratchet-Driver-58-Piece/dp/B0037GQ3B4/ref=sr_1_2?s=hi&ie=UTF8&qid=1364565506&sr=1-2&keywords=flexible+hex+bit+driver
post #409 of 758
post #410 of 758
Got these pieces cut. Not as bad as I thought they were going to be but still not fun...
post #411 of 758
Not long now. You're setting a high standard (wood working) with those cabs. Thanks again for talking so many pics.
I can't wait for my UXL's to ship.
post #412 of 758
I'll be done with the bracing tomorrow, and I should have the bottom panel and hatch finished by Tuesday:
Because my jig saw royally sucks, and it's easier of course, I'm going to keep the original bracing for the mouth as well. I also think it looks better than the new design.
post #413 of 758
For the love of God why???? Haha, 8x18SI's 12x2226 2xRLP monsters 4xultra's??? You will certainly jump into first place. My goodness I will fly to Cullyfornia to hear that if you don't die before I get there from heart palpitations...
post #414 of 758
If North Korea ever makes good on it's threats, you can hide your kitty cat in that thing. biggrin.gif
post #415 of 758
Yeah, I guess maybe I should hold out on getting anything more...at least for a bit. biggrin.gif
Plus, it sounds like stormwind has dibs.
post #416 of 758
When you build the Othorn's they will feel like a joke compared to the GH's. 36x36 seems tiny in comparison and only 5 horn path pieces! Plus it's only 4 sheets instead of 7 of cutting.
post #417 of 758
No there are some other changes. I have separate plans for that build. And the drivers will load slightly differently but looking at Akabak it should be negligible with the two evening each other out. Most of the major differences in loading for the 2 drivers occur up higher in the bass range anyway.
Ricci: if I do dual alpines instead of the uxl does everything above panel G stay the same? I have that much done on my two. Haven't cut driver holes or done bracing yet but all the panels except G are in.
post #418 of 758
Honestly, I probably wouldn't have the funds laying around to make it work anyways.
post #419 of 758
Yes those are probably the hardest pieces in the cab to get cut right and installed. Extra adhesive and some screws go a long way. Looks like you are getting close.
Ok. The only different pieces are the braces in the mouth, the driver baffle itself obviously and those 2 extra little braces in the throat shown in the screenshot in your post. I did change the bracing in the last turn before the drivers a bit too but you can just go with whatever fits in there really.
post #420 of 758
Okay, do you have the measurements for the placement of the drivers on the G panel with the dual drivers? I can figure out the bracing easily enough.
Before I make a decision, I know no one has built it with the dual Alpines. I have no problem waiting for the UXL's to become available. The dual Alpine's would be slightly cheaper but that's not a major concern either. The main issue is that no one knows when the UXL's will become available. If you were in my shoes which build would you go for? I do have an FP14000 clone for powering two Ghorns.
Thanks! Really appreciate it.
