AVS › AVS Forum › Audio › DIY Speakers and Subs › Dual GJALLARHORNs!
Dual GJALLARHORNs! - Page 15
post #421 of 758
Is there another possible fold for this monster? Perhaps with one dimension of 7' or 7'6"?
post #422 of 758
It can definitely be refolded. But, you have to find someone willing to do it. It is not a trivial process in most cases.
post #423 of 758
I am willing to try, i just need to understand what I'm doing first. It seems to me that all you really need is a spreadsheet that shows the length of each section of a given slope. All of these different segments of different slopes added up give you the total length of the horn. Is this correct or am i missing something? Does a table like this exist somewhere?
post #424 of 758
Originally Posted by N8DOGG View Post
I just got word that mine will be done middle of next week! My drivers will be ready tomorrow too! weeeeeeeee!
post #425 of 758
I've got the drivers but unless I can find someone to pick up my subs, it looks like it will be 2 weeks frown.gif I'm busy this weekend and the woodworking place is 1 1/2 hours away. I'm hoping my friends who is getting the other 2 can pick up all 4!
post #426 of 758
Sucks that you have to wait another two weeks! So mach five has your UXL-18's ready? Mark told me I was top of the list, but I haven't heard anything mad.gif. Sounds like Canadian favoritism tongue.gif My truck is at the mechanics, so I don't have an easy way to pickup the plywood anyway...
post #427 of 758
N8 used different cones. We are still waiting until he gets cones for ours.
post #428 of 758
Ah, good to know. Either way I'll be a few weeks before I have everything ready anyway. Luke sure has set the bar pretty high with the quality of his work.
post #429 of 758
He has done great! Really helped me out with my build looking at his pictures.
post #430 of 758
Ya I had the baskets and motors already. I used different cones. We had to do some surgery to get the cones on some blown drivers but it worked out great. If you bought hw many drivers I do, I'm sure you'd get a bit of favoritism! plus the 15 minute drive makes life pretty easy biggrin.gif
post #431 of 758
Hatch is 21"x21"
post #432 of 758
post #433 of 758
Ran out of threaded inserts, but these are ready to go on:
post #434 of 758
You guys always make the Hatch cover so easy to do. Fits like a glove.
post #435 of 758
Those dang hatches took friggin forever...
post #436 of 758
Looks like I'll have the side panels on tomorrow and then they're ready for Duratex!. Unfortunately, Monday I leave for CA for the week and won't be also to start that last step until next weekend...so close!
post #437 of 758
Freaking outstanding Luke!
post #438 of 758
Figured I would post these here too for any of you building these cabs.
Here are the basic response flattening EQ settings for the G horn and Othorn (REW and mini-dsp format). I recommend using these first and then EQing for the room response. They allow both cabs to be crossed over at 100-120Hz or even 150Hz for the Othorn. I recommend a 100-120Hz low pass for the Othorn and 55-80Hz for the G horn (50-60Hz is best but it can be used up to 100hz with the EQ if needed).
Also for the Othorn you want a 18dB/Octave Butterworth high pass filter at 23-24Hz.
For the G horn you want a 18dB/Octave Butterworth high pass filter at 13 or 14Hz if you will be really cranking on it with HT bass.
GJALLARHORN BASE EQ SETTINGS DCX2496.png 26k .png file
GJALLARHORN BASE EQ SETTINGS MINIDSP.png 23k .png file
OTHORN EQ
OTHORN BASE EQ SETTINGS DCX2496.png 24k .png file
OTHORN BASE EQ SETTINGS MINIDSP.png 20k .png file
post #439 of 758
OTHORN EQ
Thanks, Ricci!
post #440 of 758
Now that I'm back in town, I did a little more work tonight:
post #441 of 758
Time for some finishing work:
post #442 of 758
Quick question.
Will the XXX work with the GH?
post #443 of 758
Quick question.
Ricci had said the XXX is very much unsuitable in a horn.
post #444 of 758
Figures...Thanks.
For some reason I was under the impression that any of the "more capable" subs would be a good match.
post #445 of 758
Looking good Luke!
post #446 of 758
I'm gonna be soooo jelly if you get your up and running before me tongue.gif
post #447 of 758
post #448 of 758
Soooo...how does it sound?
Here were the questions I had going in:
1. On any non-sealed sub I've ever had, port noise has ALWAYS ended with me selling it and going back to sealed. Would the GH have port noise/turbulence?
2. Can one of these really outperform my quad 5400's with 16,000+ watts of power?
3. Would the beefed up bracing help with the cabinet resonances?
4. Can this design really handle 4,000+ watts of power?
Sooo...
1. ZERO port noise or turbulence, and I hit 117db at 15hz at the LP before my ears cried uncle. I also had the mains powered off, so all I could hear was the sub
2. Yes, one of these actually does outperform quad 5400's down low, and dare I say, it sounds better!
3. I heard nothing bad from the cabinet using Ricci's basic EQ settings. However, I put a 60hz filter on it to limit the upper frequencies.
4. Yes, yes it can.
post #449 of 758
I can't wait to see the graphs!
I wonder if you could set them on the side and use it as a coffee table.
How much vibration is there in the panels when played at 117db?
Get some videos if you can. It's always fun watching your vids. It's even funner showing them to people who aren't into HT. biggrin.gif
How much does one Gjallarhorn weigh all complete?
post #450 of 758
You do know the sealed fan boy club (basically the entire AVS DIY section) is going to tear you to shreds, right? biggrin.gif
The measurements on data bass seem to indicate that from 15-30Hz its actually pretty evenly matched vs quad LMS.
Could you elaborate on how it outperforms it?
I'm not opposing your opinion by the way, just curious on why you think its better.
Edited by Decadent_Spectre - 4/15/13 at 8:54am
