Originally Posted by
lukeamdman
Can anyone recommend some hurricane nuts that actually work? I've had terrible luck with these things, but definitely need them for this project.
I would use
these, much better than hurricane nuts.
You don't need precise alignment, don't need glued in, will never pull out, much better bite into the wood, never cross thread, you can use any thread type, readily available, and they are cheaper!
I have used them on a couple of projects and will never use anything else going forward.
Edited by jpmst3 - 1/31/13 at 5:50am
