AVS › AVS Forum › Audio › DIY Speakers and Subs › Dual GJALLARHORNs!
Dual GJALLARHORNs! - Page 25
post #721 of 758
Originally Posted by chrapladm View Post
Well it definitely sparked my interest. And as long as it doesn't cost $1000 I might even be able to make something happen. wink.gif
It could cost that much or close. It is a 21" driver after all with nice specs. We shall see though.
post #722 of 758
Db.com says 2k...
post #723 of 758
That's crazy expensive!
post #724 of 758
That one driver being talked about is REAL painful on the wallet. Like a tax audit or a divorce. Useful excursion limit is around 20-25mm one way. The driver, Zod Audio, the amplifier and the PaleHorn are all forged from solid unobtanium unfortunately with certain key components cast in unaffordium on top of that.
You guys remember the first rule of Fight Club? That pretty much applies to all of that stuff until I hear different...
Originally Posted by d_c View Post
I think I like v1 due to the ease of getting the driver in and out. Not that it has to be done often, but you would have to remove the magnet to get it in there without scuffing up the surround.
There are dual side hatches. The magnet does not have to be removed. In fact there is room for an even bigger deeper driver. The hatch is actually 15.5" wide. Shouldn't be that bad.
Originally Posted by lukeamdman View Post
My thoughts exactly.
After feeling the TC Sounds 18" VMP radiators, which I think use the same basket, cone, dual spiders, and surround as the 5400, you couldn't get the cone to move in a non-linear fashion no matter which way you pulled/pushed/twisted on the bolt for the washers. It was shocking how the only movement was perfectly linear. If that's the case, I don't see the way the driver is mounted in V2 ever being a problem, but I know some will say otherwise.
The VMP uses a heavier cone, heavier stiffer surround material, different stiffer spider, etc...Just saying.I don't know how big of an issue sag would be either, but while I'm attempting to improve things it can't hurt right?
post #725 of 758
post #726 of 758
The Zod reminds me a lot of the B&C IPAL 21. The Zod does have a lot more motor though.
post #727 of 758
the ipal 21" driver comes in at bl^2/re of 521 from my notes.
it is available to oem companies only.
this is public information and unrelated to fight club rule #1.
b&c measures resistance after intensive sine wave testing...current spec for re is 1 ohm, i believe it was measured as 0.7 ohm in the preliminary document that may not have included the "warm up".
Edited by LTD02 - 12/13/13 at 12:23pm
post #728 of 758
Hey Scott :-)
post #729 of 758
yes and no. If you pay 2000 x 2 and 600 for wood then you have 100.00 for screws etc then you have 4700 for 2 bad ass subs. I had that in 2 jl audio fathom f113 and they wouldn't compare to this.
post #730 of 758
DANG! All I got is this...
post #731 of 758
can this be built using a different driver? Im just saying if the named driver here is not available can you use a lms ultra?
post #732 of 758
you can use a uxl-18
post #733 of 758
post #734 of 758
See if you can score one of the UXLs from the group buy that someone may not need/want.
post #735 of 758
Think he is asking about the Palehorn and if you can use another driver. Guessing the answer is no.
post #736 of 758
"can this be built using a different driver? Im just saying if the named driver here is not available can you use a lms ultra?"
did you ever solve your mid-bass problem?
post #737 of 758
ok, I have a disease... I have 2 marty subs right now, and they are solid... my only problem is this... I haven't built something for too long and I want to go nuts.... am thinking of just adding 2 more marty subs, but also wondering what a Gjallahorn will do in my room... my main room is 22x12 and it opens up into a kitchen, another 8x22 room and the back hallway (it's a southwest ranch style home so everything is open floor plans with no doors for those areas... since the Gjallahorn does great for open spaces where room gain is minimal I was wondering if one of those would do the trick.... or maybe a second one biggrin.gif
since I haven't read EVERY post... can you power one off of an Inuke 6000 or IPR2 7500 channel? or would I need an LG clone...
post #738 of 758
worm...would the Gjallerhorn mix okay with the 2 Martys? I did not know if you were planning on running all at same time.
Also, would your mains do okay crossing at 60-70 to match with the FR of the Gjallerhorn?
Also...I believe you don't need a lot of power for a driver in the Gjallerhorn...you should be able to rock it with one channel of either.
post #739 of 758
I would replace the martys... use them as coffee tables in my beddroom setup biggrin.gif
yeah, I have the Cheap thrills SEOS and those go down to 65 hz easy peasy
post #740 of 758
I run one of my G-horns off 1 channel of the 7500 and it does an awesome job!! With a minidsp, you could get the martys to play with the G-horns fairly easily. If I can do it with sealed and an IB, you can with ported and the G-horn.
post #741 of 758
It's only really a matter of setting your delays properly. And hoping they aren't out of phase too :-p
post #742 of 758
A single channel of a 7500 is more than adequate.
post #743 of 758
is the palehorn a new design in the making? im gaining more and more respect for Mr. Ricci. genius!!!
post #744 of 758
That is a new design, likely with a 25hz tune and designed for high sensitivity 21" pro-style drivers.
post #745 of 758
sounds like this one is more suited for PA's... live sound?
post #746 of 758
Yes, but so was the Othorn, and I wouldn't trade those for anything for 25-150hz sub duty.
post #747 of 758
i just wish the drivers for these Ricci designs weren't so expensive!  imagine death metal never sounded any better through an Othorn. and... the viking names is just icing on the cake. BRUTAL!
post #748 of 758
Drums kicks are so powerful they're almost painful. Your eyes squint with each kick even though you know it's coming, and your vision distorts.
post #749 of 758
wow. this i must build. i imagine an othorn wouldnt sound to good with some LS9 line-arrays. with delays and what not. ive always wanted a sub that could produce life-like kick-drum with great authority. is the palehorn designed to be louder or play a little lower?
post #750 of 758
Both...but good luck getting your hands on that ZOD mystery driver!
