AVS › AVS Forum › Audio › Audio theory, Setup and Chat › speaker arrangement
speaker arrangement
post #1 of 2
I am setting up my 5.1 home theater in my basement and need some advice with rear speaker placement. The room is about 35' x 25' with the TV mounted on the longer wall. The area for the TV is 15' x 15'. Right now I have the center just below the TV and the right and left front speakers a little above the TV. Because the wall to the left of the TV is so far away I currently have the rear speakers mounted to the ceiling a little behind the seating area pointed down toward the seating area. Is this the best setup or should I mount them on the back wall which would be 8'-10' behind the seating area? There is one obstacle I have to worry about and that is the HVAC ducts that go down the area parallel to the TV. The speakers are behind this from the TV.
Thanks so much for your help.
Sean
post #2 of 2
Ideally, all speakers should be placed so the tweeters are at ear height. If you can't do that, pick either above or below and make all three fronts the same height. Otherwise, as "action" moves across the screen the sound goes up and down which sounds strange and IMO annoying.
I'm not a fan of speakers in the ceiling. If it were my room I'd put the rears with the tweeters at ear height too. This article shows the recommended arrangement for 5.1 speakers:
How to set up a room
You may find this useful too:
Acoustic Basics
--Ethan
