AVS › AVS Forum › Audio › Soundbars › TV speakers for my mom
post #1 of 11
So my mom wants her TV louder and I know it sounds horrible so I was looking at sound bars but there to long. The shelf the 26" TV is on is only like 29" long. Sooo I thought about monitors like the M-Audio AV40's or the $89 Bose companion computer speakers BUT then I realized those don't have remotes for the volume frown.gif. What can I get? Also she doesn't need very much bass, or non at all, basically anything better than the TV speakers, like a couple of 3-4" speakers would be just fine.
Edited by ScaryFatKidGT - 12/7/12 at 7:11pm
post #2 of 11
Anyone?
post #3 of 11
Maybe the Boston TVee model 10 since it can learn your TV remote commands.
post #4 of 11
To long I looked at them
How does the remote thing work? Would you wind up changing the TV volume and stuff too?
post #5 of 11
Still looking, any 2.1's or 2.0's with RF for a universal remote?
post #6 of 11
Don't think anyone makes a 26-inch soundbar. The Boston just learns your TVs IR signal for volumes. You have to turn the TV speakers off though, not sure if your moms TV can do that.
post #7 of 11
Does anyone make a set of powered speakers that use an IR remote?
post #8 of 11
What is the exact model of the TV?
post #9 of 11
Dynex LX-D26-10A
So nobody makes a pair of speakers with a remote to control them like a sound bar?
post #10 of 11
Originally Posted by ScaryFatKidGT View Post
Dynex LX-D26-10A
I just did a quick Google search. Never heard them but what about these? I'm sure that the sound quality isn't great but either should help her hear the TV and have a remote:
http://www.bestbuy.com/site/Royal+-+WES1500+Wireless+Speaker+System+with+Remote+Control/4567149.p?id=1218487075826&skuId=4567149
http://www.4homespeakers.com/rowediwispwr.html
post #11 of 11
The only Dynex 26-inch I can find is the DX-26L100A13, which has a headphone jack. Try plugging in a set of headphones and see if you can adjust the volume using the TV volume. If that works, just get a standard set of PC speakers, set them at midrange volume and let her just adjust the volume using the TV volume.
  Back to Forum: Soundbars
