So I am comparing the 1513 to the 1613 using this chart...
http://usa.denon.com/US/Product/Pages/productcomparision.aspx?pIDs=AVR1513(DenonNA)|AVR1613(DenonNA)|AVR1713(DenonNA)|AVR1913(DenonNA)&catID=AVReceivers(DenonNA)
It seems like the only differences I MIGHT care about are -
1.) It uses spring clips. Is this a huge deal? My current AVR uses spring clips, and the wires have never 'fallen out'. Is there a sound quality difference between spring clips and binding posts? Or is it a matter of simply not tripping over your speaker wires and having them come loose?
2.) Audyssey setup. What is this anyway? Isn't it just a way to automatically configure your speakers? Can't I do this manually with the 1513? Assuming I dont mind spending time monkeying with setting manually (which I DONT mind doing), what am I missing here?
And I think that's it. For 150 bucks difference all I would be getting is a bunch of crappy internet radio, network support, and other stuff I will NEVER use (I am hooking this thing up directly to my PC via optical). All I care about is SOUND QUALITY (for my 4x Polk Monitor 60s, and a decent sub & center), so is there any reason to go 1613 over the 1513?
Thanks for any advice!
*or perhaps is there a different avr you would recommend in the 200 price range?
*oh also, all the xx13 Denons carry audio over HDMI right? My last Onkyo was 'hdmi pass through' only, which meant I had to run a separate optical cable in ADDITION to a HDMI cable when hooking up my PS3. I wont have to do this with the xx13's right?
