I just recently setup my Yamaha Sound Bar with my new Sony KDL-50EX645 http://www.crutchfield.com/p_15850EX645/Sony-KDL-50EX645.html?tp=35945 and have some questions since I am uncertain if I am getting the best audio. I have my Samsung HD cable box connected via HDMI to my TV. I then connected the optical cable from the TV to sound bar. I have a very large room about 21x13 but I am about 11 feet from TV. Just having a hard time determining if this is the right sound bar or worth the money. To me it maybe worth it to return and use the regular speakers. My questions are:
1. Is this the best setup does the optical out use 5.1?
2. Should I disable the speakers on the television?
3. Should my cable box be on fixed or variable and how can I adjust the equ on the device or is that not possible with sound bars?
4. Are there any other specific configuration settings on the sound bar or tweaks I should make to it out of box?
Thank you in advance
Edited by Hugobarb - 12/9/12 at 7:53pm
