AVS › AVS Forum › Audio › Speakers › Upgrade from athena point 5
post #1 of 10
Been a long time since I have checked the audio forums but I think it is time for an upgrade. This forum saved me from HTIB in 2005 and I ended up with athena point 5s and a dayton sub. Now that I am upgrading to an HDMI receiver (denon 1713) I am thinking about upgrading the speakers too.
I have tried looking for options but it seems as if most of the threads are for floorstanding front speakers and as much as I would like them, I have limited space and need to stick with bookshelf size speakers all around.
Speakers are used for 95% movies and gaming, 5% music. Can anyone recommend something in the $5-600 range that would be a clear upgrade from the Athena Point 5's?
post #2 of 10
A clear upgrade would be subjective - however, I would prefer these >
I would look at the HTD Level Two, bookshelf and center speakers
http://www.htd.com/Products/level-two-speakers/Level-TWO-Bookshelf-Speakers
http://www.htd.com/Products/level-two-speakers/Level-TWO-Center-Channel-Speaker
However, for a little bit more - my favorite is Cambridge Audio >
And the bass goes down to 60 hz
http://www.crutchfield.com/p_779S30DO/Cambridge-Audio-S30-Dark-Oak.html
This is the center
http://www.crutchfield.com/p_779S50B/Cambridge-Audio-S50-Black.html?search=cambridge_s50&skipvs=T
Edited by zieglj01 - 12/7/12 at 10:10pm
post #3 of 10
Thanks Jim, I will check those out.
When you say you don't know if it is a clear upgrade is that because the point 5's are better than I think or because there aren't many decent options in that price range?
post #4 of 10
I am saying it depends on the individual - I have owned some Athena speakers before,
and I consder HTD and Cambridge better performers.
post #5 of 10
How would the speakers you recommended compare to the Energy cb-10, infinity p163, and paradigm atoms? Those were the names I kept seeing over and over so they were stuck in my head.
post #6 of 10
I have not listened to the CB-10, and I am not drawn to them - and Stereophile was
not impressed with them. >> I still prefer HTD and Cambridge over the Primus and
entry level Paradigm and PSB speakers.
However, the Infinity is still a nice option for movies and games.
post #7 of 10
Spent some time reading the "floored by s30" thread and they seem like a good fit although I am still tempted by the p163 for $60 each. At least I have narrowed it down to two choices. Tough decision when there isn't anywhere local where I can go listen to them.
I would hate to think I am upgrading for no reason, would there be a noticeable difference in power or quality compared to the athena point 5's?
post #8 of 10
I hear that there is a thread about the Cambridge.
I also used Cambridge for Home Theater
Power or loudness is subjective, and based on your needs. The Cambridge can get
loud for me in a 20 x 30 room - you seem to have a smaller room. > Quality wise,
I will hands down take them over the Athena and Infinity.
As far as loudness (if that is your main concern), then the Infinity will play a little
louder.
This is another subjective review here.
http://www.amazon.com/Cambridge-Audio-Speakers-Dark-Pair/product-reviews/B004NDN9NK/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
Your option, and your call.
Edited by zieglj01 - 12/8/12 at 10:43am
post #9 of 10
So if I went with four of the S 30s, and the s 50 center, would you recommend replacing the 10 inch Dayton sub also?
post #10 of 10
Yes - however, it depends on your budget.
  Back to Forum: Speakers
