Hello all, I recently purchased the Viewsonic Pro8200 and after checking on the forums I painted my wall using the Behr upw paint recommended N8 and the image looks great, although it was a little dark using my time warner HD cable box and the ps3, didn't think much of it as I didn't calibrate it yet, but even after using some recommended settings from ppl here on the forums and then using the Digital video essentials blu-ray calibration disc I could not get the settings to look right through the PS3, thought something was wrong going through the A/V receiver so I hooked it up directly to the projector, no luck, dark images had no detail at all even with brightness turned all the way up with no lights on in the room and the adjacent wall blacked out (still have a light color ceiling/wall and floor)
I even changed out cables to see if that was an issue, tried both the HDMI ports on the projector. I then hooked up my computer to the projector directly via HDMI, same cable/port and what do you know it works fine, I can see the pluge pattern in the calibration disc just fine with brightness no where near 100 on the projector and just default settings of video on my computer. Using software VLC and cyberlink powerdvd for videos/blu-rays. Blu-rays look just perfect running them through the PC, but for some reason it just doesn't like the PS3 or my cable box. I have tried the various settings on the PS3 under display settings with just about every combination, RGB on limited/full, superwhite off/on, deep color automatic/off, etc... Bright scenes look just fine, just the dark scenes are way too dark and no detail at all. I felt like I have tried just about everything, can anyone recommend anything else I haven't tried? I would appreciate any help, thanks.
Edit: I forgot to mention I also thought it could be the ps3 but I hooked that up with same cable to my 42" samsung plasma and looks perfectly fine there, pluge pattern shows up as expected.
Trade/sell-off/move the working 1590 to another TV and upgrade. Just my amateur opinion. It could be the 1590 has the option somewhere (maybe with (risky) f/w update or something. Good Luck.
