AVS › AVS Forum › A/V Control & Automation › Tweaks and Do-It-Yourself › Splitting Composite
Splitting Composite
post #1 of 3
Hey Folks have a video hook-up question ( I hope this is in the right sections of the forums)
Adding an expansion to the bar I currently work in, that I do all the A/V, Lighting and Sound for)
I have 8 Toshiba 27'' LCD Tv's I want to hook up to a computer system with a Composite Output.
the tv's are on the 4 corners of the bar back to back (attached to a 2 inch post to have room for cabling).
Coming from the PC i have a Generic Composite Distributor/Amplifier) 1Input to 4 Outputs.
My question(s):
Can I take Y-Splits from each output and attach 2 tv's from a single output from the distributor?
Or is there a "Thru" output on the TVs?
Or do I just have to run multiple distributors to get my signal 1x8?
Audio is not needed just Video..
Thanks for taking the time to look at this, and offering any insight or help....
Need any more information on my setup just Ask!
post #2 of 3
No
Doubtful, but only you can answer that.
yes
post #3 of 3
You know that composite video on large screen monitors, even just 27" looks like @^$$, right?
  Back to Forum: Tweaks and Do-It-Yourself
