Hi guys,
My xbox360 broke down and I'm trying to build a Gaming PC.
I have a regular old pc which serves me well for all non-gaming related stuff.
I'll be building a new PC just for games (replacing the xbox)
I currently have a 32" Bravia EX720 3DTV which I'll be using as a monitor for this new PC.
I'm aware that PC's can output more than 1080p, but I play at a distance at which I find 1080p enough. So no multiple monitor or surround 3d for me.
So, I have 3 questions:
1) Since I'm interested on 1920x1080p 3D as the max res of this new pc I was wondering if you could help me draw the line between what's a good enough pc to run crysis 3 with all maxed and when putting more money it's overkill.
my barebone specs: (overkills?)
8GB ram (or 16Gb)
GTX560 (one or two on sli)
i5 (or i7, what model I don't know, since I've been a console gamer for a while I also don't know how many cores are games actually using)
HDD (SSD?)
whatever mobo the core needs
My preferences: fast and stable fps over visual quality.
But since I'll be building from scratch would also like it to run games for the next 3 years.
2) Regarding the use of SSD over HDD, I usually don't play more than 4 games at a time, I'm somewaht bothered by install times since I don't se that on consoles, I don't turn off my pc that much I 99% use sleep, like I said I would only game on this pc. so what would you recommend?
3) I've seen hdmi only supports max 1920x1080@24Hz on 3d, so again that's the most res-wise I'll be using.
(I'm a console gamer trying to convert to pc so don't be to hard on me).
Thanks in advance!
8GB ram (or 16Gb)
HDD (SSD?)
Thanks in advance!
I am considering a second SSD dedicated to caching of the most commonly used files for the HDD, but I'm not sure if anyone has built a drive-specific caching solution yet, or just a system-wide one.
