Originally Posted by ChopShop1
To be honest, I am a real newb to the more complex part of the diy stuff. I have built enclosures, set up systems, etc. but the level of complexity that a really good, well setup system is still a bit beyond me at this point. I read that the DCX with rew was extremely easy to use. Someone may enlighten to the minidsp and I could go with that, but at this point, that is what I based my decision on.
Hahahahaha..I know, I just get waaaaaayyy over anxious. I am just psyched to get going on it all.
REW is way more complicated to set-up than the plug-n-play Omnimic and from what I understand, the DCX is no where near as user friendly as miniDSP. Based on everything I hear from forum users, I think you would be more satisfied miniDSP w/omnimic combo.
Not sure how many different placement options you are looking at with all of your subs, but if you wanted to go a bit over kill, the 10 x 10 HD would give you room to grow/expand and look super cool mounted in your rack!
