AVS › AVS Forum › Video Components › Home Theater Computers › simple question
simple question
post #1 of 3
I am in the middle of my build, my chassis has 3 fans, but my board has only two chassis fans outletsbut it has 2 cpu outlets and 1 power fan outlet. Which one should I connect my third chassis fan too.
Also anyone with experience with the grandia 08, my optical drive is not ejecting, I belive I may have to use a different alignment. Thoughts?
post #2 of 3
On the Silverstone case - there are adjusters on the eject button to make sure it "hits" your optical eject button. You just need to slide it forward a little so it engages your optical drive eject when you press the case eject button.
Toys
post #3 of 3
You can use Y-Cable 3Pin Molex to 4x 3Pin Molex to connect up to 4 case fans to a fan connector of the mb (each of the 900rpm stock fans consumes < 0.1A).
