AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › NEW JVC DLA RS66/X95
NEW JVC DLA RS66/X95 - Page 5
post #121 of 138
Thanks for the replies everyone. JonStatt, you're pretty much spot-on with your assessment of 80 ms of latency. I've painstakingly adjusted my audio delay to 78 ms - and I did so before even seeing your post.
Gear mentioned in this thread:
post #122 of 138
I had my X95R ISF-calibrated last week. Below you'll find the results. Are these results pretty close to what others have seen post-calibration?
post #123 of 138
Just wondering is there firmware update for the jvcx95? I see that on the uk av fourms there was a firmware fix regarding 3d shift or something like that. I looked on the us website and nothing.
post #124 of 138
Just noticed a weird white level carry-over bug in my X95. If you start by using the THX (which uses the Super White mode), then select one of the unmodified User modes (using the Standard white level), the Super White mode's attributes briefly carry over. I determined this using the Spears & Munsil 2nd Edition disc's contrast pattern.
Along with the discovery, I've learned that contrary to what some reviewers and posters have said, it seems the projector is most accurate on the contrast front when the Super White HDMI mode is engaged.
Using the S&M 2nd Edition contrast pattern, you will be able to clearly see the projector clips the contrast bars in the Standard HDMI mode. It pretty much looks like this:
However, with Super White HDMI mode engaged, the bars display properly as seen below:
post #125 of 138
I think it depends on the other eqipment in your chain.
The X-95R has three settings; standard, enhanced, or Super White.
In my room when I select super white I get the clipped levels that you show in the contrast pattern, but when I select 'enhanced' then it displays as it should.
post #126 of 138
Interesting.
post #127 of 138
I have no clipping if I use Enhanced, and that's what I do.
post #128 of 138
Just one more: I use Enhanced to prevent the clipping.
post #129 of 138
About a week ago, my projector lamp started making a 'rattling' type noise and nothing I've tried has caused it to subside. Has anyone else experienced the same problem with the DLA-RS66U? The projector used to be so quiet and now it's very distracting to hear this noise, especially during dialogue scenes or quieter moments. And, no, I don't have the projector mistakenly set to 3D for brighter (and louder) lamp mode. My projector is only a couple of months old. Thanks.
post #130 of 138
Sounds like it may be the fan. Better contact your dealer or JVC support.
post #131 of 138
Here is my situation:
I bought the new RS 4910. I had it calibrated. It measures 630 lumens low lamp and 880 with high lamp. This is on my 159" 2.4 gain screen. Low lamp measured 13 fl and high lamp 19 fl.
I have a chance to pick up an RS-66 at an incredible price, I could sell my 4910. But the 66 specs say 1200 lumens and this year's models (4910) states 1300 lumens.
Do you think the one I have is brighter or will the RS-66 be brighter. I am not be any means an expert at rating brightness. I know since the RS-66 parts are all matched and hand picked, quite possibly it could still be brighter than the 4910.
Any opinions?
post #132 of 138
Any opinions?
Did you see the email I sent you this morning or get the phone message I left you?
To answer your question, the 4910 is brighter than than the 66.
post #133 of 138
You are not going to notice any brightness difference. They both use the same lamp. Unfortunately your screen is too big for a JVC unless you get a smaller HP or use low lamp until you drop below a brightness level you require then switch to high lamp.
Mike
post #134 of 138
No Mike, I temporarily lost my cell phone and have been on an all day search, and I didn't check my mail lol. I will get right on it. Thank you.
post #135 of 138
Mike, I just sent you an email with the information. I was talking to someone I know in California and their good friend had bought an RS-66 and only used it 100 hours, so I was just curious about it as it's lower in price than the RS-57 pre-order price, he just wants to sell it off. I figured I could sell my replacement for the 4910, but I am not sure how much better the RS-66 would look.
post #136 of 138
Mike
My last projector was the RS-50 which I had for three years, and on the 159" screen it seems nice and bright, but also I do have a 2.4 gain DaLite screen.
post #137 of 138
The email did not come through. Could you send it again?
post #138 of 138
An RS66 is brighter than the RS50.
