Originally Posted by
Tom Bley
Sodaboy, I picked up this set on New Years day after my Vizio 60" that I bought it early November went out. Brought it back to Costco. I really like the picture of the Sony, despite some of the pro reviews. I'm going to try your calibrated settings. I use OTA input and HDMI from my PS3 for Blu-Ray and some streaming from Hulu Plus and Netflix wired 20Mbps internet connection. What input are your calibrated settings using? With what instrument did you calibrate the set with? And lastly, how do you tell what lcd panel the tv is using?
If you're using the Netflix interface that's built into the TV, I don't think it uses calibrated settings. You can't even configure the settings for that.
The inputs I use my calibrated settings on are TV and HDMI 1. (HDMI 1 has my PC, XBox360 and PS3 connected to it through an AVR.)
I used an i1Display Pro, PS3, AVSHD 709 AVCHD disc, and ColorHCFR to calibrate my TV.
To find the LCD panel, press Left, Right, Mute, Enter, Mute, Menu to enter the Service Menu. Panel type is listed at the bottom. Mine says Sharp something something. (At work now and can't say the EXACT text.)
I've updated my calibrated settings, just a smidge, since I last posted. Here are the new ones...
Picture Settings
Picture Mode: Custom
Backlight: 4
Picture: 93
Brightness: 50
Color: 44
Hue: G4
Sharpness: Min
Color Temperature: Warm 2
Noise Reduction: Off
MPEG Noise Reduction: Off
Motionflow: Standard
CineMotion: Auto 2
Advanced Settings
Adv. Contrast Enhancer: Off
Black Corrector: Off
Gamma: 0
Clear White: Off
Live Color: Off
LED Motion Mode: Off
White Balance
R-Gain: -6
G-Gain: -5
B-Gain: 0
R-Bias: 0
G-Bias: 0
B-Bias: -1
I also did some "calibrated" settings for Warm 1 as well. I put calibrated in quotes because the standard is to do a calibration in Warm 2, which is 6500K. Warm 1, after "calibration" is 7500K. Sometimes, I prefer a slightly cooler temperature for Japanese animation and some video games.
If you want those settings, I can post those as well.
