I am currently using a Prismasonic 1400 with front element. I am looking to upgrade from this lens to improve focus at the edges of the screen when 2.35 content is being shown. The 1400 I am using is also a bit too small for my set up / projector.
I was looking at the two lenses noted in the subject line, primarily from a price perspective. I am not sure which one would be the better choice for my particular set up. I might also add that I will more than likely move to a 4K set up in the next two years.
I am currently using a Sony VPL 95 and a Lumagen XS 3D. I leave the lens in place and use the XS to change aspect ratios. My screen is a 2.35 Firehawk, 96" wide and the projector is 12.5' away from the screen.
Thanks in advance for your advice.
Well, perhaps I would make just one tiny modification. If you have a lens like the UH480 with CA/focus/astigmatism correction, there will be little value to upgrading to a lens with variable focus unless you are operating outside the sweet spot of your existing lens. Unless you move often, focus is something you set up essentially once, and it is possible to order a lens fine tuned to your install location from certain manufacturers.
