I know I'm late to the game, finally getting a Wii in 2012, but It's been worth it! Great fun.
The setup provides so many option that trying to get the perfect setup is a hard to do with the slim instructions. I'd rather make a start with best practices too, before having to resolvle a huge mess.
Memory
Does memory available affect performance? Will games play poorply as Wii memeory fills up with game saves and channels?
If memory for a game is in the Wii and is moved to Scard, the game follows the save to the SD card. Correct?
Now, if you Copy the games save blocks from the Wii to the SD card, what does the game use? Which save is the active and which is the backup, or are they mirrored?
What happens if the games save data is copied back from the SD to Wii memory? Which is used then?
Confusing, no?
Sensor bar
The sensor bar placement, is that critical. There doesn't seem to be one non-sloping surface for me to put it on. I have mine on the top of the TV and it's got a slight tilt back, does that matter?
Audio
The Dolby PLii encoding seems to be working through the analog RCA plugs of the component cable. Simply enabling "Dolby PLii Game" decode on my AVR seems to work. Should it be that simple?
DLNA
What DLNA options are there for the Wii. Any DLNA channels/apps that will pickup DLNA servers? Or even just music from a USB drive?
Screeen settings
480p or 480i? I know the 480p is intended for higher spec HD/EDTVs but I honestly can't see a difference over 480i using component. Is htere any benefit/burden to 480p?
Hah - Quite a start, I expect I'll have more!
In the meantime... TIA!
Dave
Memory
Confusing, no?
Sensor bar
Audio
DLNA
Screeen settings
Dave
