Hello all.
I'm in the process of upgrading my system by expanding the storage and setting up FlexRaid. Right now, I have an AMD X3 + HD5670 build, but moving to an Intel i3-3225 w/ HD4000 build.
Can any of you recommend a quality MB that's good for setting up 6+ HDDs (understand I may need to buy a separate Sata PCI card in the future). Budget is around $100.
My upgraded system components will be:
Intel i3-3225
SanDisk Extreme 240GB SSD
Seagate 3TB (x4)
WD Green 2TB (x2)
G.Skill 4GB Memory
Ceton InfiniTV 4
Corsair 480 PS
Fractal R4 Case
Thanks all.
Intel i3-3225
Seagate 3TB (x4)
WD Green 2TB (x2)
G.Skill 4GB Memory
Ceton InfiniTV 4
Corsair 480 PS
Fractal R4 Case
Thanks all.
