PRICE DROP!!
I have 2 CARVIN DCM 1204 4 channel power Amps.. These are the older ones not the Newer class D Digital That sell on Carvin site for $549 New...IMO these are Better..Carvins are MADE IN USA!! There is 4 separate Amps in the 2 space Rack 3.5"
You simply can not find a better amp Value anywhere!! that's a $95.00 a channel for 200-300 Blistering Watts Each!! They are in Excellent working and cosmetic condition from a smoke free home!! The Fans are very Quiet and you WILL NOT hear them when your System is on!!
These amps are Hi end Pro Audio/Live Sound/DJ or for your Home Audio/Theater.. These amps were way over kill and too much power for my Speakers,, I can not afford to replace my Speakers so I downgraded the AMP.. These have Balanced 1/4 Jacks.. and will need 1/4 speaker jacks you can get from Radio Shack for $5
Price for 1 Amp is $380 each, Shipped to your Door with Tracking anywhere in the USA incl Hawaii,Alaska
PayPal only please to Confirmed Add,
If you want Both I will Sell and ship for $700 to your Door for 8 Channels of Pure heavy Duty Power!!!!
Mfg web Manual here
http://www.carvinservice.com/crg/manuals/DCM1204.pdf
POWER AMP SPECIFICATIONS:
MODEL DCM1204
Both Channels RMS Continuous
4Ω (20-20k Hz, <1.0%) 300/300/300/300w
8Ω (20-20k Hz, <1.0%) 200/200/200/200w
Bridged RMS Continuous (ch 2-3)
8Ω, (20-20k Hz, <1.0%) 600w
THD (Typical—1/2 power): 0.03%
Damping Factor: >350
Slew Rate: bridged mode >50v/μs
Sensitivity: (4Ω, Vms) 1.0 V
Signal to Noise Ratio: Above 100dB
Frequency Response: ±0.5 dB, 20 Hz to 20kHz
(±1.5 dB, 10 Hz & 40 kHz)
Input Impedance: >20K Ω, balanced
Power Requirements: 120VAC 15 Amp circuit minimum
240VAC 8 Amp circuit minimum
Fuse Internal-above AC cord : 25AMP slow blow
Protection Circuits: Short Circuit • No Load Protection • SpeakerGuard™ • Thermal Shut-Off • Mute On/Off
Control and Indicators:
Front: Power switch • Recessed attenuators • Signal LED • Clip LED • Protect LED • Power Indicator
Rear: Ground Lift (each channel) • Parallel Input Switches • Speaker Output Bridge Switch • Limiters
IN/OUT Switch • Input Connectors: Four; Balanced 1/4” • Speaker Output Connectors: Three highcurrent
Twist-Lok (one bridged) & four 1/4” connectors
Dimensions: 3 1/2" High x 19" Wide x 10" Depth (2-space)
Net Weight 23 lbs
Edited by flyingvfreak - 12/15/12 at 1:04am
