AVS › AVS Forum › Audio › DIY Speakers and Subs › jbl 3731 bottoms
jbl 3731 bottoms
post #1 of 5
http://www.performanceaudio.com/buy/JBL/3731/18705 I have the horn sections but trying to determine the most ideal box for the bottoms. I have 3) jbl 2226s but the box per spec for the 3731 is tuned to 40hz. I want the most punch from at the lowest 60hz on up to the 350 hz xover point. More than likely subs will cover from 80hz on down. Suggestions?
post #2 of 5
Don't you use six TD15's already?
post #3 of 5
I do have 6 TD15x but 2 aren't in use and as I get ready to finish the center channel I was thinking about changing them all to jbl. I at least wanted to try the center to hear compared to what I have now. If I like it more I'll swap out the the other 2. If not I'll go the other route.
post #4 of 5
Hmm. Interesting that you would want to change them all out. Is there something that the AE TD's don't provide?
Anyhoo... you could try picking up a couple 2226's and trying them in the same cab you have the TD's in. That would be the simplest solution all around. Test out as your center channel.
post #5 of 5
On movies no issues on music I'd like to see if better can be achieved. I got a huge increase in clarity, vocal presence, and impact when I switched out to the big boys. Now I wanna make sure i'm not leaving anything on the table. I'll try out your suggestion re the jbl in the existing box. Thx Scott!
