AVS › AVS Forum › News Forum › Great Found Deals › Inexpensive LED light fix ($1.99)
post #1 of 5
I just got a new Panasonic TV which has a piercing red power light which can not be turned off. I thought about putting a piece of tape over it but then I could not see if it was on with no source. I found these... http://www.lightdims.com
for $1.99 it fixed my problem plus I used it on a few other things.
You can get a pack for free with 1.99 s&h
or get over 100 for $5.99 plus .99 s&h
I thought for $1.99 it was a definite deal.
post #2 of 5
layer a few small pieces of scotch tape over the LED. not nearly as bright, but still able to be seen.
post #3 of 5
Scotch tape is ghetto! Light dims are awesome. Yes, they are overpriced what what they are but STILL they are a cheap fix AND look good.
I love the varying tints as well. Of course I am the weird guy who also buys port cover to put over unused RCA jacks and usb inputs. I HATED the fact that my Oppo 103 has an exposed usb port while my 93 had a cover! :-)
To each their own, but I love my light dims...
post #4 of 5
I like it.
post #5 of 5
Just buy some dark window tint and apply however many layers necessary to dim light.
  Back to Forum: Great Found Deals
