AVS › AVS Forum › A/V Control & Automation › Remote Control Area › iRule and PS3IR-1000
post #1 of 3
Have all the Global Tach stuff setup and working correctly, and am looking at the Schmartz PS3IR-1000.
Do I understand correctly that I would use a 2.5 to 3.5mm adapter and a cable to directly connect the PS3IR-1000 to the GC Gateway?
If not, can someone explain how I would get the PS3IR connected for use in iRule?
Thanks a bunch for any insight.
Geoff
Gear mentioned in this thread:
post #2 of 3
Finally found my answer.......
post #3 of 3
Hi ghannam
I've got the same question. So what's the answer?!
Goro007
  Back to Forum: Remote Control Area
