I just went to a local FutureShop and listened to a GT50 and ST50 they had side by side. No buzz at all even on bright scenes (and I put the GT50 in torch mode - Vivid, 100% contrast, etc., which I am nowhere close at home). Yes, the noise in the store is loud but I put my ear to the panel and could barely discern quiet hum on the mostly white scenes. When I have the volume loud at my house, I can still hear the buzz when I do exactly the same thing I did at the store. There IS a variation in the buzzing loudness between panels.Originally Posted by brannigan
I traded in my st60 twice and all 3 buzz the same. Panasonic just messed up when they designed it. Some test group probably showed that most people didn't mind it and they sent it through even though you would have to own it to fully realize how annoying it is. Hopefully they fix it on the newer models. I had to get used to it for awhile and it gets easier but still irritates me sometimes when I'm trying to enjoy a movie and a long quiet scene with the right colors to crank up the buzzing comes on and drives me insane for a couple minutes. Kind of messes up the moment and takes you out of the movie. Anyone that doesn't hear it is lying or has hearing problems.
Edited by 2tvsonecup - 12/15/12 at 5:55pm
But I can say that my 4th set had virtually zero buzzing even on the brightest of slides.... had an Oct. 2012 build date if that helps. However, it had to be returned with tears for a different defect as I initially thought I finally got one that was perfect.
