Hi all,
After seeing the Viewsonic Pro 8200 for $700 with a $50 gift card recently on Newegg, I sprung for it. Overall, it's not bad. But I do seem to have a pretty serious issue with focus uniformity.
I can either have the top-left or the bottom-right focus. If I focus somewhere in the middle, both of those areas are somewhat blurry.
See how blurry the clock is in this pic? https://dl.dropbox.com/u/36854688/proj/1.JPG
And how blurry the top-left is here? https://dl.dropbox.com/u/36854688/proj/2.JPG
Now I understand that I can't expect perfect focus uniformity on a cheaper projector like this, but this just seems absurd. What's the point of 1080P if the pixels are so blurry that a focused SD image would look better?
Can anyone offer me any guidance? Should I just get a cheaper and brighter 720P projector? Or is it likely that this unit is actually defective, and I should replace it?
Thanks for any info.
I wrote to Viewsonic's support and got a rather surprising answer: (for the record I'm projecting 1080P via HDMI)
Dear Mr. *******,
Thank you for contacting ViewSonic E-Mail Technical Support.
I apologies for the late update on this case. This projector doesn't have the greatest lens. If you focus on one point, a different part of the image will get blurry. The projector is really meant for video or movies. The text will never get truly sharp on that particular projector. The text will never get sharp on VGA. It can look slightly better if you uses the HDMI port and maxes out the sharpness.
If you have other technical concern, feel free to contact us again. For future reference, you can use this case number C1162666 in contacting us again. Thank you for giving us the opportunity to assist you and for supporting ViewSonic.
Sincerely,
Teresa
ViewSonic Technical Support
Sincerely,
Teresa
