Does anyone else with a Crown XLS Drivecore have an issue with subsonic content triggering some sort of undocumented "protection" mode in the amp?
I have a XLS Drivecore 1500 that I've been using to test out my new DIY subwoofers (each a 2 ohm load) until the Crown XLS Drivecore 2500 I bought arrives from the friendly UPS delivery man. I have the amp setup to run stereo and the subs are a 2 ohm load. Long story short, I discovered while playing the War of the Worlds pod emerging scene the amp goes into a temporary protection mode where the thermal lights flash and the output is muted momentarily. After a few seconds the flashing stops and output resumes. This was at -10dB on my receiver and the amp was not working that hard. (the -10dB lights were on pretty solid). Turning the volume down a little didn't solve the problem. The issue still happened even at -20dB on my receiver.
It's not a straight thermal issue since the amp will play through other extended bass heavy scenes from other movies without any issue. Further, this protection mode triggers at the same point in the scene every time regardless of whether the amp has been pounding for minutes (presumably heated up) or has been idle. When I engaged a 2nd order Butterworth HPF at 15Hz in my MiniDSP and then the scene plays fine. This leads to believe that it's not thermal protection, but something else that's not documented.
As a final confirmation test I tried playing low frequency sine waves through the amp and found it pretty easy to trigger this undocumented protection mode. The lower the frequency, the lower the volume where this "protection" kicks in.
Here's what I found.
Frequency : receiver volume where the protection kicks in
20Hz : no
16Hz : no
15Hz : -4dB
10Hz : -12dB
5Hz : -18dB
As a point of reference the amp seems to run out of power at about -4dB when audible distortion from the sub starts so I didn't push any further. My receiver was fed full scale dual channel mono sine waves (0dB?) from my PC via a digital connection (HDMI).
Are these amps just not suitable for sealed subs where no subsonic HPF is used or do I have a lemon? I sent an e-mail to Crown, but haven't heard anything back yet.
20Hz : no
16Hz : no
15Hz : -4dB
10Hz : -12dB
5Hz : -18dB
