AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › My "New" Sony VPL-BW5 Projector
post #1 of 18
Somebody has this projector for sale locally for $300. He says he will also include a remote-operated "roll down" screen, wall bracket for the projector, and a 25 ft. HDMI cable. Says it is in "great condition with no problems." He said he has never replaced anything, nor has he had any problems.
Is this a good deal?
post #2 of 18
post #3 of 18
Lamp has 906 hours.
Screen is 54" high x 67" wide.
post #4 of 18
Originally Posted by Amber Ale View Post
Here is some basic info on the projector
Link on AVS
Link to projector central info on
Old reviews from amazon
Projector reviews specs of it
I have already read all those websites about it after doing a Search. My question is not about its specs or detals...its about whether or not it is a "good deal" for $300, with an 86" screen included.
post #5 of 18
How much is the cost of a replacement bulb? Factor that into your total purchase price.
post #6 of 18
From the quick searching I did, seems like they can be had around $200-$250...but I also read that the lamp life is supposed to be 3,000 hours when used on "Normal" mode; so shouldn't it be awhile before I would have to buy a new one?
post #7 of 18
Anyone else care to chime in? The seller said he will hold it for me until tomorrow...I need to make a decision on this quick!
post #8 of 18
Well I just picked up the projector and screen. The seller demo'd it for me before I bought it, and I was happy with what I saw. Seems to be in great shape, and the picture wasn't too bad either.
I now have 2 obstacles to figure out:
1). How to mount the motorized screen so that it will lower itself in front of my wall-mounted Panasonic ST30. Ceiling-mounting is not an option; I have seen "special" brackets made that allow the screen to come 6"-12" off the wall...maybe going to end up having to buy one of those.
2). Connecting this with my Onkyo 709 receiver, which only has 1 HDMI "Out" --> does this mean that I am going to have to choose between plugging in the projector and my TV? Or buy one of those splitter switches so I can have both going into the HDMI "Out" port?
post #9 of 18
That's too bad you only have 1 hdmi out. You can buy an hdmi switch on monoprice for $50 or so to solve that problem though.
post #10 of 18
After doing some research I think that I do actually have 2 HDMI outputs. I saw there was a 2nd one on the back of my receiver, but it reads "(Sub)" so I assumed it was only for audio...but from what I've read, it is the same as any other HDMI output. I am going to start setting this thing up now. We will see!
post #11 of 18
I have a 709 as well. You'll need to find the correct output settings. I set mine as "both" going to both my plasma and older Sony VPL-hs51.
Best of luck with it and enjoy the new toy.
post #12 of 18
Can you elaborate on the "correct output settings" please?
post #13 of 18
Sure, I had to ge fire up my plasma and receiver to remember . In your on screen menu for the 709 just pull up the very first setting and choose HDMI out. As just plain "both"., at least that's what I did. I also have another projector that is out of commission at the moment that I rotated between it and the Sony. Both worked best for me. Some of the choices would not output to one of the two projectors. I forgot which. So, more than just "both" may work for you.
post #14 of 18
So I just set everything up, and the projector was working great when watching cable; however, when I put a Blu-ray into my PS3, the projector read "Frequency is out of range" (or something along those lines).
I have HDMI connecting my PS3 to my Onkyo-709 receiver. I have HDMI connecting my Panasonic TV to the receiver via HDMI (Main). And I have HDMI connecting my projector to the receiver via HDMI (Sub).
Can anyone help me out with this?
post #15 of 18
I did some research on this^ issue, and came to the conclusion that I just needed to change the Output settings on my PS3 to only support 480p, 720p, and 1080i. My new question is, though:
Do I have to go into the PS3 settings and change this every time I switch between by TV and projector? Or is there a way to make the PS3 automatically change to 1080p for the TV and 720p for the projector?
post #16 of 18
Anyone?
post #17 of 18
Here are some pics of the projector mounted on the wall:
post #18 of 18
To see more pics of my room, its progression, and current setup, see my thread here: http://www.avsforum.com/t/1394237/my-theater-room-build
