AVS › AVS Forum › Video Components › Home Theater Computers › Need a good low profile graphics card...any recommendations?
post #1 of 16
Sick of the banding problem that Intel just can't seem to fix so I'm looking for an inexpensive, quiet, low profile graphics card. I do zero gaming and just need something to handle video duties on my HTPC. It needs to be able to do 3D as well. Which is better...Nvidia or AMD/ATI? Thanks.
post #2 of 16
Low profile puts a dent in choices. A GT 640 or GTX 650 will handle anything media, and any current renderer.
post #3 of 16
GTX 650 doesn't have any low profile cards that I see.
OP the lowest you would want to go I'd say is GT 430 for bitstreaming support and such. If you don't care about that, go cheaper and get a GT 210.
post #4 of 16
Definitely need bitstreaming support. I basically use my HTPC for watching TV with my Ceton cable card and watching blu-ray rips from my NAS. My rips are 1:1 MKVs, and I have some 3D blu-ray isos as well.
post #5 of 16
ASUS GT 430 (there are lot of GT 430/GT 630=440 cards with lower effective memory clock, you'd better avoid them).
post #6 of 16
Looks like a good deal. Thanks for the help everyone.
post #7 of 16
I have the Sapphire LP 6670 and like it quite a bit.
post #8 of 16
I have an Asus Nvidia GT520 it has 2 gigs on board memory, it's low profile, it's silent has all the bells and whistles and it works very well. Can be had with or without a fan without and you'll lose the slot below.
post #9 of 16
I agree with Dave. I use the Asus GT520 (http://www.amazon.com/gp/product/B005J4XMFW/ref=oh_details_o03_s00_i01) in two of my HTPCs. It comes with a full and half height slot cover. It does TrueHD and DTS-HD Audio Bitstreaming over HDMI. The added bonus is that it's passively cooled. No fan to make noise. Pretty decent price too! smile.gif
post #10 of 16
I think I have that exact same card. The only complaint is the large heat sink makes getting access to the clip to remove the card difficult on my machine. Disclaimer--I've not tried 3D with it.
Why am I not seeing any mention of ATI cards in this thread? I thought ATI was generally preferred here?
post #11 of 16
ATI is now AMD and AMD has issues with their drivers and software compatibility with their video decoding hardware, making Nvidia the golden standard for HTPC graphics cards.
post #12 of 16
What I don't like with AMD HD 6xxx are:
- Slower video memory and system memory communication (no biggy unless you know what I am talking about). HD 7xxx (including Trinity) do no suffer from this problem.
- For BR 3D with a HDMI 1.3 AVR, you will need another GPU for HD audio bitstreaming. If onboard video (if exists) supports HD audio bitstreaming (SNB/IVB/Llano/Trinity all do), you can use it.
What I don't like with GeForce are
- No full RGB support right out of the box (can be fixed).
- The worst clock for 24/1.001 Hz. Creating a custom resolution is a fix, but that causes another problem with the clock in 3D mode (so you will have to switch back and forth between 2D and 3D).
- No 88.2KHz/176.4kHz audio sampling rate (no biggy unless you are an audiophile)
Edited by renethx - 12/12/12 at 6:39am
post #13 of 16
Thanks. Yes I knew about AMD buying them out, and can only remember which company they bought out because ATI begins with the letter A and also has three letters.
I had missed that switch in preference with ATI though. I never liked them because I hated their monthly release of updates. I called releasing software based on the calendar as being a "rolling beta" program. I believe they recently stopped that, so it's ironic that they ave now having more driver issues.
post #14 of 16
Seriously? To me that's huge! So all stream rates are not created equally? Its important not to just verify that a card will do HDMI audio, but also enumerate the supported sample rates? Does this info. exist anywhere?
post #15 of 16
Perhaps I am the only source of information on the Internet. Most audiophiles use a sound card to play hi-resolution audio files so that almost nobody cares for the sampling rate supported by HDMI audio.
post #16 of 16
Hi Renethx, I'm in the same boat than the OP. I found two issues (among several others) with Intel HD 2500. The first, I cannot use the Quicksync decoder and madVR when switching from 59p (desktop) to 23p (movie), this is now a known bug. The second is the really bad picture quality playing back my 1080i60 home videos with MPC-HC and madVR.
Since I do care for the sampling rate supported by HDMI audio, which Low Profile card would you recommend: HD 6570 or HD7750?
Regards.
