AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Resolving black or flickering screen with new bluray players
post #1 of 4
This is more of a public service note in case anyone else have the same problem. After spending almost 2 days and going through 3 different new bluray players from multiple brands and a pile of HDMI cables, it was sheer luck i managed to resolve this.
If you just bought a new bluray player, connected to the tv and experiencing the following symptoms:
1) Solid black screen but still active video signal
2) Constant flickering screen
3) Stutter in actual bluray playback (and eventually turning into flickering or black screen).
The issue might be your video output mode, in the bluray player setting try switching from YCBCR 4.4.4 to YCBCR 4.2.2 That resolved my problem!
I have a vizio 55" led tv (vf551xvt), every other device connected to it works perfectly (ps3, directv, appletv etc..), but no matter what bluray player i choose, all of them shows the above symptoms, i was at my wits end..
Anyway hopefully this will help someone else who run into the same problem. Also i would love to hear the explanation why YCBCR 4.4.4 doesnt work but 4.2.2 works perfectly. I have the latest hdmi cable (spent $40 to get one of those ripoff higend cables just in case that was the issue) and a pretty standard 2 yearold 1080p tv.
post #2 of 4
do you have the 24P turned on in the blu ray?
I beleive its more of the tv then the blu ray player.
Jacob
post #3 of 4
Jacob
i tried both on and off for the 24p and it made no difference, it's the 4.4.4 vs 4.2.2 that fixed the issue.
post #4 of 4
It's kinda funny that I ran across this tonight. I literally just took back a Samsung bluray player for this exact issue. I just hooked up a Sony, and I had already swapped out all of the cables multiple times. The only way that the bluray player would work was connecting it directly to the TV. I have my bluray player running through a 4x4 matrix switch, and on all of my TVs on each output, i get normal signal, with an intermittent flicker about every 2 seconds, where the screen basically shows "snow".
After reading this post, I went and changed this YCBCR setting from 4.4.4 to 4.2.2. After changing this setting, the flicker disappeared. :-)
Thanks!!
