Hi All,
after stalking the forums and asking a few members if i can "Borrow" some of there Ideas:D, i i have finally started my HT build,
Room and Equipment specs are;
Dimensions 13.8" x 25" x 10"
Paradigm Signature S6 for front LR
Paradigm Signature C5 for Center
Paradigm Signature ADP3 by 4 for SRL/R BSRL/R
Paradigm Signature Sub 2 for Bass
Anthem AVM50 3D For processor
Anthem P5 Amplifier for Fronts, Center and SRL/R
Emotiva XPA 2 for BSRL/R
Epson 6020UB Projector
Elite Projection Screen 138" diagonal ( 54" x 127" viewing area, AcousticPro Viewing Surface
Fusion Collection Lagoon-1011 recliners
The design of the room is evolving every day, but here is my attempt at a visio to represent what i have planned;
The main room is solid reinforced 6" concrete block filled with cement, its a room off my garage that i added on, as the visios show, 1" off the concrete walls i will be putting my 2x4 framing with IB-3 brackets and stuffed with R19, then 5/8 ply, two layers of 1/2" drywall with green glue in between layers, i am going with carpet on the floor, i hope this will provide good sound proofing,
My media rack "if you can even call it that" will be under the stage to the front, i got a design in my head, "Its if i can actually build it" we will see, but it will have doors for access and four Cooler Master MegaFlow 200mm fans for ventilation when the doors are closed,
Please let me know if the dimensions / seating distances etc looks good, also if the room has enough sound proofing, my master bedroom is about 30 feet away after you enter the house from the garage, i am hoping the sound wont escape into the attic area and affect the master room despite the distance away,
Bryan AKA Bpape designed my acoustical treatments for the walls, so it will be a mix of 2" OC703 in various layers on front and back walls and 2" cotton on the side walls from full floor to ceiling covers at certain areas to 5' high at other areas,
some before and after pics of the actual room;
(DOH! i thought i had a completed pic of the outside but seems that i don't
, i will upload when i get a shot in the morning)
So here is the crazy plan, i want to get the room finish in time for Christmas, or before new year, i know it may be wishful thinking especially since i don't have a Master builder like BIGmouthinDC, and its only me one doing all the work
, but i guess i will see how it goes, i took vacation as off Thursday 5th December 2012 throughout the rest of the month to have time to work on the room,
This is where i am at so far;
Measuring and building all the stud walls, then lifting them up, squaring and leveling up, securing them with IB-3 Clips and Concrete anchors, cutting and installing R19 and starting to add ply was not fun to say the least as my background is in IT and not construction, but i kept thinking of the little train that could throughout the entire process
I only have one more wall to screw ply onto plus the ceiling, then i can start installing the first layer of drywall + green glue, i am not puting R19 on the ceiling as i purchased spray foam for the ceiling/rafters
In the pics you will see that i only ran piping in-wall for the light switches, all other electrical/speaker wire feed conduits will be run via soffit and down into columns, i will be using my existing Homeseer installation for lighting automation etc from my mobile, i also bought a iPad wall bracket and will be putting an ipad in the room for a more permanent control interface, it will be flush mounted on the wall as you enter the room
As i mentioned the plan evolves daily, this is the current ceiling design i want to do, the 45" degree pieces in the pic will have my main lights instead of the bits in the center of the ceiling, the center will be left empty for a future star ceiling, so each wall will have a piece from the edge of the soffit going up to the ceiling in a 45 degree angle similar to the pic; i have some other adustball lights for the stage and under the sofit area going around the room.
That,s all for now, any input or advice will be much welcomed
Thanks guys.
Edited by mhypolite - 12/10/12 at 8:14pm
, i will upload when i get a shot in the morning)So here is the crazy plan, i want to get the room finish in time for Christmas, or before new year, i know it may be wishful thinking especially since i don't have a Master builder like BIGmouthinDC, and its only me one doing all the work
, but i guess i will see how it goes, i took vacation as off Thursday 5th December 2012 throughout the rest of the month to have time to work on the room,This is where i am at so far;
.I only have one more wall to screw ply onto plus the ceiling, then i can start installing the first layer of drywall + green glue, i am not puting R19 on the ceiling as i purchased spray foam for the ceiling/rafters
Thanks guys.
I'm not just speaking from what I have read around here.
