AVS › AVS Forum › Display Devices › Screens › Can someone recommend an inexpensive screen ("fixed" screen) for me?
post #1 of 3
I want to improve dark scenes (contrast ratio) of my Epson 8350 with a screen. I am only projecting on a normal ivory colored wall (matte paint), and it looks good, but I want to enjoy TDK and TDK Rises more smile.gif
I'm hoping to spend less than $550, as if we start going high, it may be better to use this money towards an upgrade, like the newer Epson ones or the Panasonic AE8000 (and if we were going either route, I wouldn't get a screen).
So I'm looking at a fixed screen where I can mount it to a wall like a normal LCD/plasma TV. Any good recommendations guys?
post #2 of 3
Have you tried looking at the Monoprice screens? They are really nice looking and easy to install. It's just a matter of installing two simple brackets and having it hand in the same manner as you would install a TV.
Depending on the size you are looking for, there are plenty of options below that price point.
http://www.monoprice.com/products/subdepartment.asp?c_id=108&cp_id=10829
post #3 of 3
I bought the Monoprice Fixed Frame Projection Screen (8cm Aluminum Frame w/ Velvet Wrapped) - HD Grey Fabric (133 inch, 16:9) (Monoprice.com) about two weeks ago.
Price is great but watch out shipping is unexpectedly high.
I really like it... wasn't too bad to put together and hanging it (The top bracket which actually holds it up) wasn't a problem at all. Still not sure I have the bottom bracket right though.
Picture quality is great - I am using an Epson 3010 against it and it looks really amazing for the price. 3D is great with that projector/screen combo to the point I don't enjoy watching 3d on my 70" sharp tv.
  Back to Forum: Screens
