AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › Need a quick temporary screen that I won't have to stretch
post #1 of 14
Hi all,
Here's my situation - I'm going to pick up a new projector just in time for a party for my child. I need time to figure out which screen to get for the long term, so I'm looking for a simple quick solution for the party.
I have a huge white wall, but the darn thing has some marks in it that won't allow me to use it as a screen.
What I'm looking for is something that I can throw up on the wall (pin, temp hang, tape, etc...) that will look good enough for this use (and maybe a few more times after that smile.gif ) Needs to be fairly light weight obviously.
I've seen the threads on spandex and black-out material, but not sure they would work without building a frame (which I could only do if it was very very light. Afraid if I didn't do that the wrinkles would kill it.
Probably need to pick it up local since the party is this weekend. Projector will either be an 8350 or AR100u.
Thanks a million for the help and advice.
post #2 of 14
Where is
"Local"?
post #3 of 14
Just use the wall. The kids will be amazed enough that they wont care about a couple marks. Bust out the rag, some elbow grease, or even a magic eraser. Why waste money for a one time thing. Plan out your permanent screen and do it right.
post #4 of 14
I used a white bed sheet for about 6 months and it was a pretty good screen. tack it to a stick top and bottom no frame required and hang on the wall. The bottom stick will be a weight to pull it down.
post #5 of 14
Thanks for the feedback everyone.
MississippiMan: Local is California. And I guess the reality is that I could order from Amazon with 2 day shipping if it was something that made sense.
Duke: Your point about the wall is a good one. Only reason I hesitate is there is one fairly large mark/hole where a damn nail messed up the wall and a picture now hangs. It's a 4-5" dark circle that would really stand out.
I'm realizing that the other reason I'm hoping for a decent solution is so my wife will love how good it looks the next night when we watch batman and won't mind the purchase. wink.gif
How would the quality of a white sheet compare to black-out fabric or spandex? The sheet is an interesting option. From what I remember it would probably be $20-40 at TJ Maxx.
If something pans out, I'm crazy enough to grab some black fabric tape and add a border, even for something so temp like this. Want the friends to love it.
Thanks again.
post #6 of 14
A 3" to 5" area is easy to fix quickly enough with 2 quick coats of Mud and some sanding, and if you take the advice below to breast, it will become wholly invisible.
ok...the easiest thing to do that would give everything a better look would be to mask off the perimeter of the screen as the PJ projects, then Lightly sand the inside of the tapedarea using a Large Sanding Sponge. Wipe clean, and apply at least 2 coats of Kikz-2 or Bulls Eye 123 Primer, lightly sand, then a 3rd coat.
Get some 3.25" MDF Base, cut it to size (can you Miter?) and paint that trim "Disney Mouse Ears" Black in a low sheen Flat Interior Enamel.
This choice sets you up for finishing off later with something truly special, or simply applying a Finish Coat of a standard but applicable paint.
post #7 of 14
Ha! I've read that 3 times and I can't figure out whether you're being sarcastic, replying to the wrong thread, or being serious. The "Disney Mouse Ears" black is what's throwing me. I'm laughing either way. biggrin.gif
post #8 of 14
The mouse ears is a paint that as far as blacks go is the blackest of the blacks.
post #9 of 14
Yeah, I figured. It was just when I couldn't make sense of the rest of it, I thought it might be a funny reference to my kids birthday party.
post #10 of 14
post #11 of 14
I know, right? :-) It's like I'm from Pluto. tongue.gif
Thanks again.
I'm guessing the above in bold isn't easy to answer, but wondering if anyone has thoughts before I head out and buy something.
post #12 of 14
Black out fabric isn't very expensive. I'd go that rather than a sheet, especially since sheets are thinner and might show anything behind them more.
I've done really ghetto screen installs with Blackout cloth pinned to the wall. Worked fine for me but I used a lot of pins to stretch out the wrinkles.
post #13 of 14
Get the blackout cloth and cut to roughly your screen size. Get some black duct tape to run around the outside of the screen to provide a border. Place it up on your wall and tack in place with tacks or a staple gun. cheap, quick and easy.
post #14 of 14
Cool. I'm going to go to Joann's now an look at the fabric. Do they have multiple types to consider, or will it be easy for me?
  Back to Forum: DIY Screen Section
