Originally posted by johnwcookjr
Hi all,
I'm currently receiving both WOWT and KETV via the attic Terk/Stick. Now that the clouds have dissipated signal strength from KETV is adequate. A few more KW's would certainly help.
KETV reception this evening was rock solid on my Dish 6000, WOWT is usually rock solid except during heavy snow coverage. If this keeps up, and the Channel Master 0062A distribution amp (still on back order) works as expected I may be good to go for the long haul.
I had company over tonight, we caught some of the Gladiator broadcast. I was glad to see ABC passing it on in its original aspect ratio and DD5.1. Our friends eyes were glued to the screen.
Looking forward to some HD sports.
Warren, anyway you can persuade ABC/IMS into broadcasting the Indy 500 next year in HD.
Jay and Warren, I'm enjoying your programming, however the constant logo watermark raises concern with CRT burn-in. can you do anything about the watermarks, make them intermittent?
John
Hi all,
John
Hi John,
On the watermark logo, that comes down from ABC, they insert it on their end, I unfortunately do not have control of it. I would hope it is at a transparency level which will not burn-in. I will contact ABC and see what they say about taking it in / out so it is not in all the time. Don't think I will have much luck though, but I will try.
Of some interest, if anyone wants to avoid burn-in, use either a LCD or DLP display, you cannot burn those. I know some people like to connect their game systems to the big screens, and that would burn-in. I would choose the DLP as its blacks will be better than the LCD display.
Question for you John, I have not connected my ATSC receiver to a surround sound system, how did Gladiator sound in DD 5.1? I can monitor the audio channels on my decoder at the station, but those are really small speakers.
--Warren
