I am just trying to understand sub calibration fully, that is all. It's an area, as you can tell, I am not too hot on.
So, as I understand it.
Delays are independent, whether the subs are mono or not. Which is good. Channel trims are not. Hence if you set subs to mono and enter the audio levels and adjust sub chan 9 it makes no difference.
Eq is completely independent and can not be summed to mono. In that if you apply eq to sub chan 9 and then mono it to sub chan 4, that eq becomes redundant and only eq on chan 4 is used. As I found in my REW measurements.
I still do not fully understand tho if Dirac filters can be applied to each individual sub and then still used when mono. Or if one is to mono then the subs need to be calibrated as a single mono sub in Dirac? Ie, one channel with multiple speakers. Sorry if I am sounding thick, it's just I have not read the info I need in a way I fully understand.
The reason why I feel that subs need to be individually calibrated, eq'd by Dirac, is as stated above, my right front sub is by an alcove which causes weird interactions as apposed to the left sub. I understand that by letting Dirac see them as one sub and performing a single channel eq can work well, but surely if it can calibrate them seperately before being Monod then the room interactions will be much more acurately taken into account.
Ie, if I calibrate them as mono, and the right sub has a big suck due to the alcove, then surely it will try and fix this by applying a lift on some frequencies across all subs, which won't be correct as this could cause a peak on the left hand sub. Am I making sense?
