"Not familiar with the term "2.0 runtime." Could you expand?"
Okay, here's the scoop. The Theta people are using a different version of Dirac Live than what is in the Datasat products. Dirac Research calls what is in the Theta Casa their "version 2.0 or V2 runtime". The V2 runtime uses a different configuration GUI than what Datasat uses. The V2 GUI is infact this tool ...
http://www.dirac.se/en/consumer-products/dirac-rcs.aspx
OEMs such as Theta add custom software to bridge between the Dirac Live application and their hardware. Datasat has been looking at the possibilities of migrating to V2 but as of yet have not made a commitment.
Is Dirac Live V2 better than V1?? Nope, my testing says they produce the same results. The only advantage to V2 is one that is important to the OEM, in that it takes fewer MIPS to process a V2 filter.
Automagically computing delays is in both Dirac Live V1 and V2. Unfortunately it was never implemented in the Datasat AP20/ RS20i. Setting levels automatically is tricky because there are so many things outside of Dirac Live that can affect them. As result I expect you will always need to check them.
_______________
Best Regards,
Carl Huff
Edited by Carl_Huff - 1/24/13 at 11:10am
