AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Marantz 6005 Capable?
post #1 of 4
First post.
I have a Marantz 6005 which is currently powering:
Magnepan MMG's in the front
Magenpan MMG C center channel
And Audio Engine P4's in the back
Am I near the limitations of this amp? I sure hope not.
I want to buy one maybe two Bic VK-12 subs.
Tell me if I am overloading this.
post #2 of 4
Originally Posted by GAA4200 View Post
First post.
You mean Marantz SR 6005, right?
http://us.marantz.com/us/products/pages/productdetails.aspx?CatId=avreceivers&ProductId=SR6005
VK12s are powered subs - they put no power load on the AVR at all.
post #3 of 4
Thanks for the reply.
Few...that is a relief about the powered subs.
Do you think I would be overloading it if I changed the rear P4's to side speakers and replaced them with two more Maggie MMGs?
post #4 of 4
At average volume levels (ie. -30db), the AVR shouldn't have any issues with the change, however, will likely shut down at louder volume levels.
