Originally Posted by jneutron
You seem fixated on this steel braid thingy...
RG-6 is a generic, it can have copper core, copper plated steel core, copper braid, aluminum braid, steel messenger wire outside, aluminum foil with copper braid shield...many different flavors.
A steel core wire with copper plating will have added inductance in the audio realm due to permeability. 15 nH per foot is the mu=1 point, multiply that by the permeability for whatever mu the core actually has, then drop it for skin effect.
A steel braid, if there, has no effective inductive increase per foot as a consequence of the cancellation of fields and the distribution of current density caused by the aspect ratio of the shield thickness to circumference.
The bottom line is, let him try what he wants, doesn't hurt anybody.
jn
jn
You seem to be an expert on electrical properties and physics. I posed a simple question. Assuming a solid copper core, is there physical and/or electrical considerations using RG6 with a steel braid as opposed to a copper braid? Answer the question.
I never mentioned copper clad steel core vs. solid copper core.
In your opinion.... if you don't have FM or AC interference, does using RG6 have any benefit as opposed to "normal" speaker wire?
OTOH, I totally agree. The OP should just experiment and use what works best to his perception.
