Originally Posted by
billnln
very crisp jn
Do coax features only work with a cylinder around a round wire?
The term coax means coaxial, so it is based on a cylindrical symmetry, a center wire surrounded by a cyndrical conductor, both which share a common center. The design works because the center of the current within the core wire (the current centroid, or center of "mass" of the current as it were" ) and the center of the shield current (which is the same place in space) are along the exact same line.
As a consequence of the cylindrical symmetry, any magnetic field generated by the core wire will be exactly cancelled by any current through the shield
outside of the shield. The shield conductor cannot produce a magnetic field inside the shield as a result of physics.. We end up with a situation where the magnetic field caused by current in the coax is only the field caused by the core wire, and that field abruptly ends at the outer shield.
This cable is a type known as "constrained". Meaning, all the e field and m field is constrained within the confines of the shield. The energy of the signal is therefore also constrained to space inside the shield.
billnln
What happens when two flat ribbons with a measured air distance between them--- run a signal?
Very close to the same thing. It is possible to mimic the capacitance per foot and inductance per foot using ribbons, I've done this quite a bit. With ribbons, there will be some e field at the edges which wil bulge out into air, and there will also be some small amount of magnetic field doing the same. But because the currents are is relatively close, the inductance will be lower by proximity cancellation, as well as due to the length of air the magnetic field must travel to get around the conductors.
billnln
Is there a measured distance that would be more specific to music signals?
Theories run the gamut, and what is considered "best" will also run the gamut. White papers will explain to you why physics says "this" is best, others will explain why "this" is worst". (substitute anything you want for "this". While the pseudoscience explanations may be well written prose using physics terms, most are meaningless...sales pitches.
It is possible to make any geometry cable to create any capacitance and inductance per foot (within a simple mathematical constraint), but whether or not it makes an audible difference for you is purely speculative.
Not impossible, mind you . But speculative.
For your coax...give it a try. Won't hurt anybody.
jn
