I'm going to be converting these dual 15" loaded cabinets to dual 21" loaded cabinets. They are 11.4ft3 internal per driver, and tuned to 31.7hz. I will be taking the old JBL 15s out of the other cabinet in favor of a pair of Eminence Kilomax 15s until I can convert the second cabinet to 21"s. The objective here is to have 2 dual 21 enclosures that I can use either on thier own or together with the other cabinets. The output capability for the size, and how these fit in the van pack space make it a no-brainer.
Drivers:
http://www.rcf.it/en_US/products/precision-transducers/neodymium-low-frequency-transducers/lf21n451
RCF 21"(teal) vs JBL 15"(green). The Kilomax 15 models almost the same as the JBL. The difference in output should be no surprise:
Here is the plan:
1. Remove drivers and grilles.
2. Remove fiberglass damping inside the box.
3. Remove t-nuts and any other mounting hardware currently installed in the driver area.
4. Sand front of box to raw wood.
5. Cut a 3/4" plate fit the face of the box.
6. PL the snot out of said plate and glue it to box face.
7. Roundover plate edges.
8. Cut pair of 21" holes.
9 Reconfigure bracing.
10. Rewire cabinet.
11. Paint black(/gasp, what?){maybe}
12. Install drivers.
13. Fashion grilles out of expanded metal sheeting.
14. 4ohm bridge on an Ashly KLR-3200, delivering 3200w per box.
15. Hurt people.
The JBL 15"s are 19.5lbs per, the 21"s 24. The most significant weight addition will be the Piece of 3/4 I graft on to the front of the box. I can and will still be able to move these on my own. I have considered using my low tuned 18" bass cannons with either Zv3 or SI 18s to provide 0-35 and use these 35 up.
Drivers:
Here is the plan:
10. Rewire cabinet.
15. Hurt people.
I figure you must be asleep by now.
