Hi,
I just bought Onkyo TX-NR616 and I connected it with a 5.1 system (Wharfedale DX-1 HCP). I updated to lates firmware (400), I did the initial setup including Audyssey but the audio output is very low. I checked all the connections, polarity is fine.
When waching TV or hearing music via USB or radio, at level 55/60 I hear at normal level. With the Avatar BR I had to put the audio at level 75 to hear it normal.
Is this also happening to any of you?
What audio level do you hear music or play movies?
Felipe
Felipe
