Hi folks,
I have been searching and give up. So I'll just ask.
I currently have a mobo with a vga monitor that uses analog stereo speakers. This is how the computer is used most of the time.
It also has onboard HDMI, but will only put out 2.0 sound. To switch between the analog and digital audio, I have to open the audio properties and then choose between the rear output(stereo or headphones) or the HDMI audio.
I want to upgrade to a graphics card that will allow me to use the computer with a vga monitor that uses analog stereo speakers most of the time, but will also put out up to 7.1 audio.
I believe I have found that the dual monitor is not a problem, but I can't find anything on the sound. I want to be able to use the computer speakers when I'm not sending things to the HDTV and then switch to digital (up to 7.1 audio) when I enable the HDTV.
I would also like video card suggestions. I do not game so I think I can use one of the lower end cards (cheap).
Thanks for any help,
Rob
Rob
