AVS › AVS Forum › Audio › Receivers, Amps, and Processors › AVR-2113ci Zone 2 Question
post #1 of 3
I just bought a Denon AVR-2113ci and I am having problems getting Zone 2 to work. I have the Zone 2 outputs hooked to an external amp via the RCA outputs.
Using both the free and the pay Denon apps for iPhone, when I turn on Zone 2 and set the source to Internet Radio, the volume sticks at "40" and blasts the speakers. I cannot turn the volume down with the app or on the Denon remote.
I went into the audio setup and it shows Zone 2 greyed out.
What am I missing? How do I adjust the volume on Zone 2? DId I miss something in the setup?
Thanks!!
post #2 of 3
Zone 2 pre-out volume on the 2113CI is controlled on the external amp. You would have to upgrade to the 2313CI or 3313CI to be able to control the Zone 2 pre-out volume via the AVR remote or mobile phone app.
post #3 of 3
Thanks for the quick reply.
I guess I have to say that is disappointing. I wish Denon had made that more clear in the spec sheet. Now I am stuck with a fixed volume Zone 2 or No 7.1 speakers!
Any suggestions for a cheap external amp with a remote controlled volume control?
