All,
I'm in the process of upgrading our home theatre and wanted to see if now might be the right time to put together a HTPC for our needs. The real question is whether I can put something together for less than what a dedicated AVR/Pre/Pro would cost. The following are the objectives of a build:
I'd be willing to spend between $1,500 and $1,750 for this build if needed as that is what a comparable pre/pro would run me; obviously if I can do it for less that would be awesome! My initial reaction is that I'm likely looking at a i5+GPU+HD HomeRun+Xonar HDAV type setup, thoughts?
- 2D and 3D Blu-ray playback
- Verizon FiOS integration (presumably via CableCARD)
- Video processing
- 1080p24 passthrough of Blu-ray
- 1080p scaling, deinterlacing, and enhancement (e.g. sharpening) of content
- Color management system for calibration (i.e. ISFccc)
- Audio processing
- Decoding of Dolby Digital, TrueHD, DTS-MA, etc.
- 5.1+ audio pre-outs for use with external amplification
- Room correction
- Simple user interface for family usage
- Integration with tablet/smartphone devices
