Hi All -
I am reluctantly retiring my Denon AVR2309 and ancient AR speakers; I'm mostly using an AppleTV (with Airplay) to listen to music, and would like a much smaller footprint. So, I would think that a set of powered speakers would be the obvious option, and am about to pull the trigger on the Audioengine A5+ (plus l'll need a DAC as well because ATV only has optical out).
I've heard the A5+s a they sound great, and I'm sure will sound even better with the D1 DAC. But as I'm looking around at options, I am seeing a class of small DAC + Amps, such as the NuForce Dia, which I would think could drive a decent set of passive speakers.
So - any thoughts on which of these options would do best? And, if I were to go the small amp + passive route, any thoughts on small-footprint passive speakers that could fit the bill? The room is about 15'x20' - so would something like the Dia have enough power to fill the room?
Thanks much for any advice!
Dan
Dan
