Hi,
I've decided to go with the Epson 8350, but the problem is I can't mount it to the ceiling. To make things worse, in front of where the screen will go I have a bunch of windows with very little space between, so I can't have a permanent shelf there.
I will have to have something that is moved into place unless there is another solution. I understand you can have this projector quite a bit off center? Here's a rough sketch of my layout:
Would I be able to have my projector either off to right or left as shown above? What are the limitations with this placement (meaning how far to the side can you go)?
Since you're going farther away from the screen, I'm sure I'd be losing some brightness, but might be worth it.
Thanks very much for the advice.
