I have been playing about with the Nvidia Control Panel in a vain attempt to get the GTX650Ti video card to output 0-255 RGB. It seems Nvidia will not allow this to be a user decided setting on HDMI and all I have been able to find is:
1. a complicated registry hack (http://forums.guru3d.com/showthread.php?t=365595)
2. a 'Full RGB Toggle' application that crashes each time, which is a worry (http://blog.metaclassofnil.com/?p=83)
3. a 'Setfull RGB' program (http://www.avsforum.com/t/1387832/htpc-tweaks-and-fixes#post_22484920) which will alter the registry but the 'undo' function will not work.
I think I may have now got it set to full RGB with the Nvidia outputting 0-255, LAV video set to 0-255 and MadvR set to 16-235 and the picture on my Panasonic Viera 65VT30 now seems to be very good. Has anyone managed to get the Full RGB Toggle program to work with the latest drivers because it seems the most elegant solution having a simple GUI to switch between full and limited RGB? Is there anything else out there?
Makes you think that Nvidia is not the ideal choice for HTPC given that ATI include the function in CCC!
