I have an HTPC running dual Nvidia 570 cards (SLI) - windows 8 pro box. Just upgraded to the SC-67 from a 82TXS receiver, and am unable to get the audio to work on the HDMI inputs. I Previously had no trouble with audio over HDMI on the 82TXS. The new receiver works just fine with all other components. I have burned many hours, and am about ready to give up and install a DTS encoding card and use the optical input.I did turn off processing on the receiver and enable passthrough. Other things I tried:
Updated receiver firmware, Changed HDMI cables, changed video card the cable was connected to, removed and updated drivers (clean install - both latest certified drivers and beta drivers). I verified the Nvidia HDMI audio driver is installed, and at one point the receiver was listed under "playback devices" in the windows audio panel as "disconnected". At this point it doesn't show up in the windows audio playback devices at all - not even as a disconnected or disabled device. I do see the Nvidia audio devices in the device manager.
I'm wondering if anyone else has had a simmilar issue with the SC-67 or SC-68.
i would appreciate any insight at this point!
